Memory_Management BSOD help?
Tormidal
124
On Mon 9/16/2013 1:00:09 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\091613-18361-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x5A440)
Bugcheck code: 0xA0 (0x10A, 0xA, 0xFFFFFA800E105010, 0xFFFFFFFFC0000001)
Error: INTERNAL_POWER_ERROR
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that the power policy manager experienced a fatal error.
This problem might be caused by a thermal issue.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
Tormidal
124
Ive been having a lot of issues with my NVIDIA drivers crashing.
Could that be part of it?
My GPU also tends to run anywhere from 30-50 degrees Celsius.
*In addition to investigating any thermal issues:
run MEMTEST or the Windows memory diagnostic.
Other:
1. Update the BIOS if a new one exists (will reset any BIOS changes)
2. Put CPU and Memory to default settings
3. Your problem may be software, but I always start assuming it's an issue with the DDR3 memory being either defective, or more likely a frequency/timing issue.
Tormidal
124
Ill check for a new BIOS version, I dont know how to install BIOS though.
CPU and Mem should be at default.
Tormidal
124
Sorry about the double post, but I updated the BIOS, check the settings for the memory and CPU, both of which were at the BIOS defaults to begin with.
Timings are in the new screenshot, after the BIOS update. Its 16GB of 1333MHz memory, by the way.
Also, uninstalled all NVIDIA related things, and re-installed. Im gonna do what I was doing, and hopefully I wont BSOD.
Tormidal
124
I will as soon as I can find the CD it was on. ;-;
On the other hand, I havent gotten the BSOD yet.
