Minecraft Port Forwarding Issues
wigglerthefish
262
Hello,
I've been creating a server that I intend for public use. I port forwarded from an Ubee router using my Host computer IP, 192.168.0.3 . I am not using an internal port (set to 0) and I have the external port set to 25565 (both start and end). Whenever I enable the port forwarding, the rest of my family is unable to print off of the wireless printer on the same network.
What do I have to do to avoid interference? Others can connect to my server, but I can't keep enabling and disabling the setting whenever I need to print.
Set the internal port to 25565 as well. Port 0 is an invalid port and cannot be used. Once you change it, enable forwarding and check to see if you can print again.
Thanks! It's working fine for now, and I'll give you best answer if I don't have any more problems in the next few days.
