Hi there. My apologies if I picked the wrong forum for this. I'm wondering if anyone could help me with possible cooling solutions for a mini-itx case. I finished the build yesterday and the CPU temp is running a bit hot at 55C-60C idle.
I've never done a build at this small of a form factor before, so I feel as if I'm in uncharted territory in terms of cooling options. There is no room for a case fan. The CPU cooler is a low-profile aftermarket that seemed well reviewed for core2duo's. The stock Intel cooler would have fit...but just barely & there were risks of it touching the NB chipset.
It seems like my only options for this case is a PCI fan (there is one PCI x16 slot on the board not being used) or a 3.5" bay solution. Unfortunately, I don't have a lot of experience with either...so I'm hoping to get some advice on what would work better and/or specific product suggestions. This is a budget htpc solution (sub-$500)...so I'm trying to keep costs (and fan noise) down.
I've outlined the specs of my system below.
Purpose & Uses:
Budget Mini-ITX HTPC for bedroom.
No overclocking needs.
No hard core gaming (maybe secondlife).
Will mainly be used for browsing & streaming music/movies (avi) from my server.
Netflix streaming & Hulu.
Case:
APEX MI-008 w/250W PSU
(Dimensions: 8.7"x5.1"x11.8")
http://www.newegg.com/Product/Product.aspx?Item=N82E16811154091
Mobo:
ZOTAC GF9300-D-E
http://www.newegg.com/Product/Product.aspx?Item=N82E16813500022
CPU:
Intel c2d E5200
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116072
CPU Cooler:
ZEROtherm ATOM 30H Low-Profile
(size: 80mm | CFM: max 29.2 | Heatpipe: Copper tubing)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835887018
Thermal Paste Used:
Arctic Silver
RAM:
4GB G.Skill DDR2 800 (F2-6400CL5D-4GBPQ)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
HDD:
WD Caviar Green 640GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136298
GPU:
Using onboard HDMI (Nvidia GeForce 9300)
Optical:
Samsung Black 22x SH-S223B
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151187
I'd be so grateful for any suggetions or advice. I've got a box window fan pointed at the back of the case for now...which is keeping it around 45C...but obviously that isn't a long term solution.
Thanks in advance for any feedback!
-Tara
Purpose & Uses:
Case:
Mobo:
ZOTAC GF9300-D-E
CPU:
Intel c2d E5200
CPU Cooler:
Thermal Paste Used:
Arctic Silver
RAM:
HDD:
GPU:
Optical:
-Tara
