Hi, long time reader, first time builder/poster. I wanted to check with yall if this was a feasible build and if things would fit and work well together (temps, power usage, airflow, etc.). I also need help in deciding the cpu/motherboard/case. I've bought most of the basic core components already through deals/black friday/cyber monday and I'm only left with the case, cpu, and motherboard, which I've narrowed down, but just haven't pulled the trigger on buying due to waiting for deals and indecision. This is meant as a budget medium gaming htpc (with the deals).
I also have a Microcenter really close by for the cpu/motherboard bundle, but I just don't know which cpu to pick. I'm not going to do any kind of overclocking so that eliminates the the unlocked versions of cpus and puts me with an h77 motherboard, but the $40 discount bundle only comes with the i5-3570k or i3-3225 cpus. I don't know if I should go with the 3570k as it makes it cheaper overall with the bundle or wait for a deal on the 3470 or 3450 as the 3570k would be underused from not overclocking.
My total I've spent so far with rebates factored in so far is $251 and I'm trying to keep it as close to $550 as possible.
http://pcpartpicker.com/p/q5w0
cpu:
i5-3450: http://www.newegg.com/Product/Product.aspx?Item=N82E16819116506&nm_mc ($140)
i5-3470: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115234&nm_mc ($150)
i5-3570k: http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504&nm_mc ($130 w/ mb bundle)
I'm leaning towards latter two
motherboard:
ASRock H77M-ITX: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157311&Tpk ($95)
case:
Cooler Master Elite 120: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119261&nm_mc ($40) or
Qubz Mini Gamer ITX: http://www.amazon.co.uk/accommodate-supply-Optical-motherboard-Graphics/dp/B0064OVFLY (~$50)
Everything else was bought at too good of a price to pass up. With the Cooler Master case, I'm worried about reported problems with temps, airflow and the cpu hsf being a cm or two below the psu and the problem on the Qubz is there is no review about it other than the few comments on amazon uk. Also, I have an unused full Windows Vista Ultimate with a Windows 7 upgrade that a friend got from his school for $30 but it's a one use kind of thing. Should I just shell out the extra $50 or so for a oem version or will the upgrade be sufficient?
Thanks in advance for any critiquing and suggestions. Any kind of help is appreciated.
cpu:
motherboard:
case:
300 watt power supply too. I undervolt the cpu to save every last watt). The cpu cooler is the Cooler Master Gemini S, but I had to mod it to fit the case(and swap its fan for something slimmer).
