[SOLVED] Missing Realtek HD Audio Manager / Static From Headphones
Nov 1, 2019
Hey all,
I recently performed a fresh install of Windows 10 from USB; everything went smooth, but I've noticed that I'm missing Realtek HD Audio Manager and its corresponding drivers. These are important to me because they enable extra enhancement options in the Sound Control Panel, and my headphones are profoundly quiet without those enhancements. Additionally, ever sense the OS install, I've had a terrible static noise coming from my headphones (which work fine on my phone, suggesting the issue is software related on the PC).
Any idea how I can get these back? I've been to Realtek's site, but I can't make sense of it. I've also downloaded Realtek drivers from MSI's website, though it didn't change/help anything, and Realtek HD Audio Manager still didn't show up in Device Manager after extracting and installing the file.
I don't know what else to try and don't know why Realtek just didn't come with the OS install.
I'm running Windows 10 x64 and a new MSI X570 Edge mobo.
Any suggestions? Thanks.
I don't know if you trust this site or not, but i gave it a shot and it fixed it for me 1st try. It tells you to buy the trial but i didnt pay a penny
https://www.drivethelife.com/thankspage/Driver Talent.html?d=https://www.drivethelife.com/download/driver-talent.exe
DO NOT use utilities like these. They are hot garbage.
Seriously, NEVER
The last time I encountered this issue I found it to be there but disabled. Go to Task Manager then Startup and see if its disabled, then Enable it. Also you should see the icon in your Control Panel. If not you may need to reinstall it. This site has a good explanation how to do that:
https://www.thewindowsclub.com/download-reinstall-realtek-hd-audio-manager-windows
Seriously, NEVER
Seriously, NEVER
guess i got lucky. It fixed the problem for me and uninstalled i immidetly. kinda annoying that it installed chromium. I unistalled that alrdy too though
