Archived from groups: alt.comp.periphs.mainboard.aopen (More info?)
Hello,
I have put together a system for a client (my father-in-law, uh-oh)
based on the MK79-N (with an Athlon 2500+, 512MB 333Mhz RAM (not the
best, Apacer is the brand), 80GB Seagate HD, LG 4082B DVD-Burner and
WIN XP Pro SP1.
When I first built the system, I had a few problems. Thought it was a
bad install. Format and re-installed. No problems. After applying the
SP1 and rebooting, I got a POST screen with all garbage text, bad
characters really. I could still read the POST screen (sorta) but it
was garbled with characters that should not be there.
I WAS geting a full stop blue screen with the first install, just
after the Windows XP boot screen (the one with the logo and the 3
little blue scrolling blocks), but not after the second install.
At this point, nothing boots, no Windows XP boot screen, after the
POST (and, of course, a check to the floppy and CD for a bootable
disk) I get a black screen.
In the end I suspect the video.
So heres the questions:
Has anyone seen this problem?
How can I tell what version of the BIOS do I have?
And how does that work for integrated Video? Can I flash only the
video and not the BIOS? I only see BIOS upgrade on the Aopen website,
and the details dont mention any video issue fixes.
How can I tell FOR SURE that its the Video and not the RAM (remember,
the RAM is used for Video memory). I can install a PCI video can I
have lying around, but that might not prove that it was video. What if
the RAM just wont work well with the Video.
Heres my thoughts: Either swap the motherboard or swap the RAM.
What do you think?
Thanks in advance, folks.
Chris P
Hello,
WIN XP Pro SP1.
What do you think?
Chris P
