MOBO and Flickering problem Need Help!
silverraven09
13
Problem 1: I have a problem with my motherboard. The ACPI LED: S4_S5_LED is on bright red when the cpu is off / shutdown ( power supply is still on ). This goes away when turned on but a green light would light up on the ACPI LED just below the S0 LED ( not the S0 LED but an LED below it ). I don't know if this is normal in anyway i have searched the gigabyte website for any information about the ACPI LEDs but there was no useful information other than:
"ACPI LEDs
The 4 embedded ACPI LEDs indicate the system power status (S0, S1, S3, S4, S5) to prevent potential hardware damage due to improper plug/unplug actions."
i have also done some research about the ACPI LEDs on wikipedia http://en.wikipedia.org/wiki/ACPI ] Advanced Configuration and Power Interface [/url]
which states:
http://img222.imageshack.us/i/acpi.jpg ] Picture [/url]
I also have tried removing the MOBO battery and putting it back after 30 mins or so.
The computer boots up fine. in fact i am using the actual computer to write this question. I am unsure if this is a thing to worry for my system. Since i had a prior shut off (2x) by itself when i was coding + multitasking ( my room was really warm/hot though around 75degF - so i wasn't sure if it just overheated... but i have like really good case air cooling on my system ).
Problem 2: Sometimes i would have some slight flickering on my triple monitors on the 3rd monitor
setup looks like this: on crossfire mode
[ 1st ] [ 2nd ] [ 3rd ]
1st monitor: DVI to displayport adapter - connected to 1st video card display port
2nd monitor: DVI - connected to 1st video card
3rd monitor: DVI - connected to 1st video card
Catalyst Software Suite version 11.4
Resolution is @ 5760x1080 Refresh Rate @ 60Hz since its 5760 x 1080
(CPU and Video cards are not overclocked in any way)
Operating system: Windows 7 Proffesional 64-bit
Monitors x3: http://www.newegg.com/Product/Product.aspx?Item=N82E16824236091 ] ASUS VE276Q Black 27" 1920X1080 2ms Full HD HDMI Widescreen LCD Monitor w/Display Port & Speakers 300 cd/m2 100,000 :1 (ASCR) [/url]
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811129100 ] Antec Twelve Hundred V3 Black Steel ATX Full Tower Computer Case [/url]
CD/DVD Burner : http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204 ] ASUS Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 24X DVD Burner - Bulk - OEM [/url]
Internal Hard Drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185 ] SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive [/url]
Power Supply: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011 ] CORSAIR HX Series CMPSU-850HX 850W ATX12V 2.3 / EPS12V 2.91 80 PLUS SILVER Certified Modular Active PFC Power Supply [/url]
Memory: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428 ] G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL [/url]
Video Card x 2 (Crossfire mode): http://www.newegg.com/Product/Product.aspx?Item=N82E16814161355 ] HIS H695F2G2M Radeon HD 6950 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity [/url]
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070 ] Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) 4 x 256KB L2 Cache 8MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I72600K [/url]
SSD: http://www.newegg.com/Product/Product.aspx?Item=N82E16820167042 ] Intel 510 Series (Elm Crest) SSDSC2MH120A2K5 2.5" 120GB SATA III MLC Internal Solid State Drive (SSD) [/url]
MOBO: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128479 ] GIGABYTE GA-P67A-UD5-B3 LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard [/url]
CPU fan: stock fan
http://img710.imageshack.us/i/cpuqs.jpg ] picture of CPU-Z and CPUID[/url]
a picture of CPU-Z and CPUID
Thank you in advanced i would like different inputs about my question so i can try them out. Thanks a bunch
Problem 1: have you tried changing the leads on the LED? I had a problem with the light being on when the computer was off because i had + on the - lead and vise versa.
Problem 2: when is the flickering happening? I have had a couple issues with flickering in my crossfire setup during some gaming, but it goes away after a few seconds. I think that it is just a driver issue and that driver updates will eventually fix it.
