Mobo cant control the CPU fan's speed
s_a_n_t_y
Hello guys! Im havin a Pentium Dual Core CPU with the clock speed of 2.5 Ghz (E5200) runnin on an Intel DG41RQ mobo. I have installed an after-market heatsink for my CPU which has a 4 pin connector. Now the issue is that, my mobo can't control the CPU fan speed even though i've enabled "CPU fan control" setting in my BIOS 🙁 and atm the fan is running at its max speed. Can anyone suggest a solution for the issue? :) thnx! :)
ya I saved the setting in the BIOS, but it is the same old story. Is it something wrong with the pin that take advantage of the fan RPM control?
What are your CPU temperatures? It may be possible that the fan is running on full RPM because your temperatures are too high, and the controller is ramping up the RPM to provide sufficient cooling for your CPU.
According to CPUID Hardware Monitor and CoreTemp, the temperature readings are:
Core0#: 46 deg. C (114 deg. F)...
Core1#: 43 deg. C (109 deg. F)...
Now what ya think about the statistics? Are the readings hot for the CPU, according to yer knowledge?
They seem fine for your E5200, is there a setting in your BIOS for SmartFan temperature? That could be set to something lower (ie 40C) that isn't being reached. I'm not sure if your BIOS would have such a setting, but you can definitely check.
I've checked the whole BIOS, the thingy does not have that kinda setting or the setting similar to what u have mentioned.
I am using Cruiser LGA775 heatsink which has a 4 pin connector which is connected to the 4 pin CPU fan header on the motherborad & I've checked for the blue wire of the CPU fan that takes advantage of the PWM functionality.
Can you control the fan with any software such as SpeedFan? If you can't control the fan through software or the BIOS, that may point to a faulty controller on the motherboard.
I installed the latest version of SpeedFan in my comp but i dont see any options for controlling the CPU fan's RPM. It only displays the thermal readings of my both CPU cores, the GPU core and the HDD temp.
Here is a great link showing you how to set desired temperatures, and adjusting Min/Max fan speeds in speedfan: http://unitstep.net/blog/2007/11/02/using-speedfan-to-automatically-control-your-pcs-fan-speeds/
I have SmartFan off in my BIOS, so I haven't tested if this does work, but it is definitely worth a shot.
hey w8, is the fan RPM control, controlled by the sensor chip of the motherboard? My sensor chip is Winbond
The way I understand it, the PWM control connected to the 4-pin CPU fan plug reads temperature data from the sensors on the CPUs die, and then provides voltage ranging from nearly fully off (lowest RPM) to nearly fully on (highest RPM). So if you can't change the CPU fan speed through BIOS or SpeedFan, then maybe your PWM controller is broken, or not supported with your current drivers.
Hey Look...I've sorted out the problem by checking with the original Intel stock HSF of one of my friends motherboard, and the PWM thingy of my motherboard is workin fine with his HSF & I've checked mines on his motherboard & my HSF was working on full blast on his motherboard with his "CPU fan control" setting enabled on his BIOS. So I guess, as ya said... my HSF prolly dont go with the PWM signal transmitted from the motherboard's sensor.
