Mobo help!
thegamersnation
22
hello everyone,
i am building my first desktop here and im just not sure as to which MOBO to go with!
price should be no more then 150$
i will be using this for gaming and i do plan to OC
thank you in advance
my mistake totally slipped!
Here is a list of a few things i have my eye on:
Monitors x3
Gateway FHX2152Lbd Black 21.5" 1920x1080 2ms Full HD LED BackLight LCD Monitor Slim Design 250 cd/m2 1000:1
http://www.newegg.com/Product/Prod [...] cafffeutf5
Video Cards x2 **(is there another brand that i should go with?)**
GIGABYTE GV-R697OC-2GD Radeon HD 6970 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
http://www.newegg.com/Product/Prod [...] 92xx1jbzwt
Hard Drives
Corsair Force Series GT CSSD-F120GBGT-BK 2.5" 120GB SATA III Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Prod [...] hu9jygb805
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Prod [...] 6822152185
PC tower case
Silverstone Tek Extended ATX/ATX/SSI-CEB Full Tower Case with 90-Degree Motherboard Mounting with Window Side Panel Computer Case RV03B-W (Matte Black)
http://www.amazon.com/Silverstone- [...] k-c1001-20
Power supply
XFX Core Edition PRO850W (P1-850S-NLB9) 850W ATX12V / EPS12V SLI Certified CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply
http://www.newegg.com/Product/Prod [...] h97u4jdb48
Processor
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) 4 x 256KB L2 Cache 6MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
http://www.newegg.com/Product/Prod [...] w4rdqr5h6n
CPU fan/heatsink
Scythe SCMG-3000 120mm Heat Pipe CPU Cooler
http://www.newegg.com/Product/Prod [...] ikvcrjexj1
DVD-CD burner & reader
Sony Optiarc CD/DVD Burner 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model AD-7260S-0B - OEM
http://www.newegg.com/Product/Prod [...] 7fd4x16wh9
Memory
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Profile Desktop Memory Model CML8GX3M2A1600C9
http://www.newegg.com/Product/Prod [...] sez8hsehns
posted what i have my eyes on, thank you
- ASUS P8P67 (REV 3.0) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131705
- ASRock P67 EXTREME4 GEN3 LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157265
- MSI P67A-G45 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130582
Theres a few things on your list that you can change for better pricing and slightly better name brands but its decent as is.
what are your thoughts on this mobo: ASRock P67 Pro3 B3 Intel P67 ATX DDR3 2133 Motherboard
http://www.amazon.com/gp/product/B004R9PCNK
If you ever want to xfire/SLI this board will not cut it because it only has one PCIe x16 slot. Its a decent board but there are better boards for less out there. By the way...I find Amazon rarely beats out newegg so always check there first!
yea i always check amazon lol. thank you for your help...i just order the asus p8p67 board...lets see how it rocks. another quick question..do you know if the pro version is worth getting?
