Mobo not detecting ram speed, help!
travcarp
23
Okay well I bought ram it's rated at something like 1600 but my motherboard is only recognizing it at 1300. How do I change it?
mobo
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813128397
ram
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820211409
P.s. One of the comments on the motherboard was;
Cons: This is only a Con for the beginning system builder. It requires a trip to the BIOS to correctly set up high performance ram. It was running my DDR3-1600 at 1066 out of the box and had the voltage set too low as well. Its autodetect for the ram is very conservatively and underclocked. I normally run through the BIOS on first boot, so this is not really a bad thing, but first time or inexperienced builders should be aware of it.
travcarp
23
Problem is that I don't know what to set these to, I never done this before - how do I know what numbers they go to?
estraulino
Hi! Sorry for asking another question on this thread.
I have an Asus P4SD-LA motherboard and it does not recognize my ram at the proper speed. I had 3GB of pc3200 but now it detects it like pc2700. All sticks of ram are pc3200, and I checked them with CPU-Z.
What could it be?
