Mod Project... Need help with deciding on a PSU.
mr_lucklegs
143
So, I"m modding a computer case and want to show it off. I'm missing quite a few updated parts,but that's not the problem. My old psu out a old Hp, cables are way to short to take advantage on my cable routing mod, so I need help finding one black psu with long pre sleeved cables fairly good wattage for some gaming when I update the guts! :sweat:
That depends on what you plan to use in your rigs. Tell us your build. I will only use something from Antec and Corsair. Seasonic is one of the, if not, the best but they are also expensive so I will only consider them if you're going to be using more than 1000W.
I dont have one I'm currently using an A8n-La board and four sticks of ddr = 2gb out an old Hp. I'm modding a case and needed something basically free to show it off, but I want to show the cable routing system I have made up. Later on I will improve it.
