I unfortunatly cannot afford a new case to upgrade from my stock HP case (H8-1010) and am looking at modifying it increase some airflow with a filter and huge external fan. I upgraded the GPU to a GTX 560 Ti 448 Core (running 90c+ under load most of the time) and the CPU to a core i5 2500k (not overclocked, and not running too horribly hot either) and the PSU to a Corsair TX750 (doesn't SEEM to get having any issues in the case).
I opened the case and put a box fan pointed at it blowing continously, it lowered my GPU temps by a good 10-15c on average, sometimes up to 20c cooler. My issue with leaving it open is I have 2 cats and 2 dogs in the house that shed like mad and I don't want everything getting clogged up.
Here's my plan:
Use a fan that is about a foot and a half to two feet in diameter blowing into the case through a filter.
Rig up an Air Filter to the open side of the case (cut it down and velcro, maybe use a metal mesh on the outside to give it some support)
The filter I'm looking at is something like THIS
The one only thing that would concern me is the fact potential static buildup or something of the sort that could cause major problems. Does anybody know of any other similarily ghetto rigged machines or if there will be any problems?
Thanks for any help you may be able to offer!
Here's my plan:
