[SOLVED] Molex Fan Help
Nov 15, 2022
6
Where does the (LED_SW) go in a Msi Pro H610M-B? And how can I change fan colours if they are connected directly to psu by molex?
Five molex fans, all connected together to one psu cable. Cannot control RGB, how can I? Where does LED_SW go in a motherboard?
I'm so confused 🙁
According to that page they are NOT ARGB fans, they are LED fans.
It says right on the description:
Note: Fans are fixed light and not controllable when boots up.
I'm so confused 🙁
LED switch is usually just off or on. As asked above post a link to the exact fans.
LED one color RGB multi color.
EDIT I see no ARGB or LED connectors on that motherboard.
https://www.msi.com/Motherboard/PRO-H610M-B-DDR4/Specification
If those are simply LED fans, then the color is not changeable. If they are RGB or ARGB fans then you are going to need to buy a third party controller because as Zerk mentioned, there are no RGB or ARGB headers on that motherboard. Therefore, there is no way to control the RGB/ARGB color or effects without adding a controller UNLESS the case has one. Most cases don't, but if it is an "RGB" or "ARGB" case, then it might. But, it matters what type the fans are as well so we need to know the exact model of the fans and the case.
