Thank you so much, this is exactly what I needed since while I could read the info on pc sites, I had no idea about the intel capping the limit, and so on. So intricate and complex. Lol your insight is really appreciated and saved me from buying something completely not workable like an i5 with 8gb ram and 2060 card.
An i5 is actually still really good for gaming.
There are 2 main measures to cpu performance:
multithread, and single thread.
Currently, i7 and i9 provide more threads, meaning better multithreading, but actually are only a tiny bit better in single thread.
While games are slowly becoming more and more multithreaded, most games now, and for the foreseeable future don't benefit from more than 8 cores at best.
(in the current generation, i5 has 6 cores, and i7 has 8.)
8gigs vs 16gigs is very situational actually.
8 is actually enough to run almost all, or actually all games with no problem.
Thing is, sometimes you have more stuff open than just a game, say you have chrome for searching stuff and spotify for music, and discord for talking with friends at the same time, all those quickly add up to more than 8 gigabytes, even if the game itself actually takes only say, 7 gigs.
And as I mentioned in the last comment, 16 is the sweet spot since, all games fit on there, and gives you headroom for whatever else you want to open without being restricted.
Another important point for the computer
He should have an ssd.
I'm sure you know already, but SSD's are the main drive of the computer (replacing hard drives, or working with them)
For the actual main drive with windows on it, and stuff that opens when the pc opens, say his favorite game, or discord (which usually opens as soon as the pc boots up) it MUST be an ssd in the year 2020.
For the bulk storage, say, games he only plays every once in a while, photos or videos for archiving, that's actually okay on an hard drive since there are still cheaper per gigabyte and have higher capacities if needed.
He doesn’t know. He plays on an i5 w 8gb ram and 1tb he’d. That’s all we know. He doesn’t know PCs well...I know more than he does, which is not good lol he is just starting to game on pc as he played Xbox before. Wants a valve index.
the "bling" of a machine is actually the last decision in my opinion, even if it's for a child.
The case, and vendor parts (meaning what company you buy the ram, or gpus from, even if they are the same card.) are the 2 more important "bling" items.
The case is quite obvious, since its the main chassis and is the main "look" of the machine
The vendor parts also drastically change the look of the inside of the machine, even if there is no major difference in performance.
for example
Ram from corsair, or ram from g.skill.
Which one looks better in your opinion? pick that one, AS LONG AS THE SPEED IS THE SAME.
say corsair has better looking ram in your opinion, as long as the speed of both is the same, you should pick the one that looks better, since the performance will be the same
Thing is, if your son is set on alienware, you really can't configure the looks of the machine.
They only have a few types of cases, and I'm pretty sure non of them have side panel window.
