MOMO and NFSU2 : gas and brake don't work !
G
Guest
Guest
Archived from groups: alt.games.need-for-speed (More info?)
I have a Logitech MOMO and in the control-panel all works fine but under NFS
Underground 2 the gas and brake are not recognized... The steering-wheel
works fine inclusing the force-feedback. What is wrong here ??
Ton den Hartog
I have the latest drivers from Logitech and the latest path of NFSU2, I just
checked both. NB running XP SP2 on an Athlon64.
I ran the stuff succesfull on a old PC (Pentium 450 MHz) and also on this
Athlon64 as it came pre-installed by the computer-shop. However had to
reinstall everything and since the MOMO only has a working wheel in NFSU2.
As said, in the Logitecg control-thinh the gas and bread DO work ! I don't
understand what is going wrong..... :-(((((
Ton
"Ton den Hartog" <ton.den.hartog@tonh.net> wrote in message
news:422b5823$0$28979$e4fe514c@news.xs4all.nl...
>NFS Underground 2 the gas and brake are not recognized... The
>steering-wheel works fine inclusing the force-feedback. What is wrong here
> Ton den Hartog
This is so weird. In the Profiles I set the physical wheel to be the breaks
and the physical breaks to be the steeringwheel. As a result the physical
wheel is dead and the physical break controls the wheel-function.... !!!
This means the hardware is fine. I already tried an english driver instead
of the ducth version but this does nit make a diference...
How can I FULLY remove the Logirech software and driver ?? It still
remembers that I foudn the NFSU2 game s not all is deleted !
Ton
> Ton den Hartog
If NFSU2 is like NFS2, you need to set the brake and throttle on the same
axis, they can't be separate, as in most other modern racing games.
Phil
news:422b882f$0$43073$e4fe514c@news.xs4all.nl...
> breaks and the physical breaks to be the steeringwheel. As a result the
> physical wheel is dead and the physical break controls the
> Ton
>> Ton den Hartog
