Monitor.exe problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
When i log into windows i get this error message-Windows
cannot find monitor.exe. Ive done a virus scan and
checked for spyware ive been into device manager and its
says ok and working properley.The monoitor comes on and
work but i keep getting this error message help would be
appreciated.
>-----Original Message-----
>appreciated.
>Ive tried disabling everything in starup an iam still
getting the message
> appreciated.
This probably has nothing to do with your monitor, it is most likely a sw
that you deleted by mistake, or something else (adware, spyware od
trojan/virus).
Try this:
Click start, run, type msconfig.exe, press ok
Try finding monitor.exe in the Startup tab of the System Configuration
utility, and the disable (by clearing the checkmark)...
I hope this helps.
Best regards,
Zoltan Fekete <zoltanf@neobee.net>
Microsoft Certified Professional
YU Spin d.o.o. Novi Sad - http://www.yuspin.co.yu
NetSee Network Utility - http://yuspin.metrohive.net/netsee
On Mon, 16 Aug 2004 05:16:54 -0700, anonymous@discussions.microsoft.com
>>appreciated.
> getting the message
Try this:
http://www.faqfarm.com/Computer/Virus/Backdoor/46435
Best regards,
