[SOLVED] Monitor for MacBook Pro (13-inch, Mid 2012) which is 13.3-inch (1280 x 800).
Jun 17, 2020
7
I am thinking of a Monitor to use with my MacBook Pro (13-inch, Mid 2012), it has resolution of (1280 x 800).
I have no idea if I buy any random monitor will it work with it or not.
Looking for EyeCare monitor, i have ready IPS are good for eye care.
Budget range is from 100 USD to 300 USD, can go a little higher as well if there is something good.
Monitor ranging from 18 to 30 inches would be good option, anything else can also be taken a look at.
Thank for great suggestions.
Can you please check if this is the same as you mentioned (
Asus 21.5 inch Full HD LED Backlit IPS Panel Monitor (VZ229) (HDMI, VGA, Inbuilt Speaker))
Following is the link.
https://www.flipkart.com/asus-21-5-...dosi0w0000001593076370308&qH=85eb83994f009d8b
