monitor going to sleep
SHELLY87
i have been using the same pc and monitor i went to turn it on and the monitor is showing going to sleep why is this please help?
Chances are the computer is not working. Try the monitor with another computer and/or another monitor with your system. Make sure the cables are connected properly. Check the computer for issues with the motherboard, do a visual inspection of the capacitors, that often causes boot issues. If those all look good, could be a bad power supply, RAM, video card. You'd need to swap those out for known good ones and re-test.
