If
this is your monitor, then it only has one analog, D-SUB input. It won't work with your graphics card without an active adapter. If you shut down your computer, physically removed the graphics card, connected the monitor to your motherboard's VGA (D-SUB) output and restarted the system, you should have gotten a display.
There are only two scenarios in which this is not the case:
- There is a damaged component.
- The integrated graphics has been manually disabled in BIOS.
In the first case, there's really nothing to do except get an active HDMI to VGA adapter.
In the second case, you can try to reset the BIOS by clearing CMOS (remove the battery from the motherboard for about 5 minutes).
Removing the CMOS battery should reset BIOS to it's default settings and if the integrated graphics were manually disabled, then resetting BIOS should re-enable them.
-Wolf sends
@Tommaso De Portu - Just a note: That motherboard supports RAM speeds of up to DDR3-2800. However, it will run, clocked down to DDR3-1600.
