I ordered a couple 6950s a few days ago and they arrived today, so the first thing I did was plug 'em in and turn them on (With the crossfire bridge)
The thing is, they just won't let my monitor display correctly. It's an AOC 2436Vwh full HD monitor, and while the resolution is set to 1920x1080, it's made itself an inch wide border on the LCD... I'm using a DVI-D to HDMI cable to connect the GPUs to the monitor.
Also, on that note, for some reason, my computer won't display off the second card, only the first one... I have yet to try DisplayPort, but I don't think that will make much of a difference.
Since they're ASUS DCII cards, is it possible the little DVI switch has been knocked over to the other setting? In which case, will it not display?
The monitor ran fine on my old GTX460, and on the 7600 GS I tested it on...
