Hi all,
I've got a 2560x1440 165hz 27inch monitor (Samsung Odssey 52a) and a gtx1070 connected via a DP 1.2. Every time I try to change the resolution to something other than 60hz, I get the message "Not Optimum Mode Recommended Mode 2560x1440 165hz".
Things I've tried:
Changing it in display settings and advanced display settings
Changing it in NVIDIA settings
I can't change it via the monitor as it's greyed out since it's supposed to be controlled by the PC
Uninstalling and reinstalling NVIDIA drivers
Turning off G-Sync
Turning off image scaling
New DP cable and port on the pc
HDMI works but capped at 60hz
I saw somewhere in the manual that I cant change refresh rate if adaptive sync is on on the monitor but when I turn it off, the screen just turns black
I'm not sure what else to do.
Thanks!
Things I've tried:
Turning off G-Sync
Thanks!
