Question Monitor suggestion for RTX 3080 and PS5 ?
Selynelar
200
11
10,615
Hi all,
I would like to ask for your help. I am having a gaming pc and PS5 as well. So I decided to connect my PS5 to my monitor as well. It works fine but sometimes feel not so smooth/laggy when I am gaming on it. Even that PS5 already supports 1440p. So I am thinking to update my monitor.
Either to 27/28" 4k 144hz or to 32" 1440p or 32" 4k monitor.
I play a lot of competitive games on pc as well so most probably the 4k is not the best choice and also I am afraid that my pc is not going to handle well the 4k when it is about gaming.
But I will listen about your experience.
At this moment my monitor is an Acer XB273UGS.
My config:
Cpu + Cooler: I7 10700k + Noctua NH-D15
Vga: Msi Rtx 3080 Gaming Z Trio
Motherboard: Msi Z490 Unify
Ram: 2x16gb 3200mhz Hyperx Fury
Case: Be Quiet Pure Base 500dx
  1. Any suggestion for monitor what handle my pc and ps5 as well?
  2. Do you think 1440p is bad picture quality on 32" and on 27/28" bad picture quality with 4k resolution?
  3. Should I stick with my current monitor?
I have some choices:
Acer Nitro XV282K KVbmiipruzx Review - RTINGS.com
Acer Predator XB323QKNVbmiiphuzx 31.5 inch 4K Ultra HD Gaming Monitor (IPS Panel, G-SYNC Compatible, 144Hz, 2ms, HDR 400, Height Adjustable Stand, DP, HDMI, USB Hub, Black/Grey) : Amazon.co.uk: Computers & Accessories
Predator XB3 Gaming Monitor | XB323UGP | Black | Acer UK Official Online Shop
Acer Predator XB323QUNVbmiiphzx - OázisComputer.hu (oaziscomputer.hu)
Amazon.com: LG 27GP950-B 27” Ultragear UHD (3840 x 2160) Nano IPS Gaming Monitor w/1ms Response Time, 144Hz Refresh Rate, NVIDIA G-SYNC Compatible & AMD FreeSync Pro, DCI-P3 98% VD HDR 600, Black : Everything Else
27'' méretű QHD IPS monitor AMD FreeSync™ (Premium) technológiával, NVIDIA® G-SYNC kompatibilitással és 1ms MBR-rel (lg.com)
Sorry for the silly questions but I am really glad to any advise.
Thanks for your replies.
A 4k HDMI 2.1 monitor.
The ps5 doesn't support 1440p so it's a no go. 32 inch is too big for 1440p in my opinion.
Are happy with it?
Recommendation:
https://www.amazon.com/GIGABYTE-Mon...28u&qid=1673230121&sprefix=M28,aps,208&sr=8-3
Thanks for your reply. So far I know the PS5 has gotten the support already for the 1440p.
I am strongly thinking about to get the 32" 4k monitor. Only my concern is that if the 3080 is going to handle well the 4k with I7 10700k Cpu and also I play a lot of competitive games as well.
