Question Monitor takes many tries to turn on
TheNostalgicOS
63
Hello, I have a Benq G920WL and whenever I try to turn it on it instantly turns itself off and It will only turn on after I keep pressing the power button multiple times.
Is there any way I can fix this so that it turns on on the first try?
Thanks!
Power button on the display or the system? If the former, then it's possible that the power button might be gummed up. If the system, then it's possible that the PSU might be faulty or failing.
Might want to share your specs with us, like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Does the issue happen when using a different power cable, assuming you were talking about the monitors power button...?
CPU: Pentium G4560
Motherboard: ASUS
Ram: 8GB Crucial Memory
SSD/HDD: 80Gb Intel SSD and 500gb HDD
GPU: Radeon 7850 1gb
PSU: 680 Watts
Chassis: Black Case
OS: Windows 10
I am currently using a different monitor and I have tried a different power cable but same result
