motherboard 4 pin power connector
Yarin Mayost
23
My mother board z77 has a 4 pin power connector on it and it doesn't work without it.
I bought a new psu ,corsair hx850
And it doesn't have that connection.
So my question is what do I do?
Will an adapter from molex to 4 pin work?
Also can I use an other power supply and just use the 4 pin connector from it? Won't it give all the power through this one cable and burn my motherboard
G
Base on your PSU spec, It have 6 PCI-e connector, 1 ATX connector, 1 EPS connector, Look for EPs Connector of your PSU, If it is 8 pin, connect the half (4 pin) to your motherboard.
https://www.google.com.sg/url?sa=i&rct=j&q=&esrc=s&source=images&cd=&cad=rja&docid=PG7Sr1qdFQegWM&tbnid=Yl1DTu7XbE6iiM:&ved=0CAUQjRw&url=http%3A%2F%2Fmundobip.com%2FCableado-Corsair-HX850-V2-Gold_312.htm&ei=CwBUUujiDMiUrgemnoGABA&bvm=bv.53760139,d.bmk&psig=AFQjCNHu-99H087CRwR47-bJJ_p9NVb_2Q&ust=1381323118781099
G
Guest
Guest
What he mean is EPS connector. Its an 8 pin together, can divide into 2.
4+4=8 pin
G
Guest
Guest
