Good morning guys!
This morning my computer started to continuously shutting down. After reading posts on this forum, I installed a software and realized that my CPU was at 109 Celcius. 🙁
I brought it to a store nearby and the guy confirmed that my watercooling fan was not working anymore. He told me to find one, order it and he would install it for me. He also noted that my ram was not working properly and that only 8gb were showing instead of my 32gb. After a few test he mentioned that my ram slots on the motherboard were deficient. He advised to change the motherboard as well.
Now, I really don't know anything about motherboards or CPU cooling. But I would like to keep my spending to a minimum if possible. ( I still don't mind spending a little more just for better quality).
This pc is mostly for multimedia and gaming. I have a AMD FX-8320 3.50 GHz Eight-Core AM3+ CPU 8MB L2 Cache & Turbo Core Technology. And my current motherboard is [CrossFireX] GIGABYTE GA-970A-DS3P AMD 970 Socket AM3+ ATX Mainboard w/ On/Off Charge, Ultra Durable 4 Classic, 7.1 Audio, GbLAN, 2 Gen2 PCIe X16, 3 PCIe X1 & 2 PCI and my CPU cooling is Asetek 510LC Liquid Cooling System 120MM Radiator & Fan (Enhanced Cooling Performance + Extreme Silent at 20dBA) (Single Standard 120MM Fan).
I guess my question is do you guys have anything you can recommend to replace my motherboard and Watercooling fan? Oh, and do I need watercooling for gaming or a regular cooling is enough?
Thank you so much for your help!
