marcovstaden6 :
So do i need to update the bios beacuase on the box rev.1.1 (srry i am not a pc pro)
You are not subject to the problem of an incompatible BIOS on the motherboard out of the box.
The 2000 series Ryzen processors would not boot with the shipped motherboard BIOS (around February 2018). They required an "AMD boot kit" to enable the motherboard for use. That was basically a first generation Ryzen (like yours) that was installed on the motherboard . Then the motherboard BIOS was updated. Then the boot kit CPU was removed and the new processor installed.
But you do need to update the BIOS to fix ongoing problems with Ryzen processors in general.
