Hello all,
I am going to build a new gaming PC and after some research, I have finally selected the components below but with your expert suggestions I want to make sure everything is compatible with each other out of the box and also I am not sure yet which Motherboard I should go with, Earlier I have confirmed ASUS ROG STRIX B550 - E Gaming but now I can't find it in stock anywhere so I search more and find out MSI MAG X570 Tomahawk WiFi is also in the same cost and I believe with same features too but I am not really a big fan of MSI products because they never work for me out of the box in past 😕Also please check my list of components below and let me know If I forgot something to add to it or did I choose any wrong or overkill component? Thanks and waiting to hear back from you
- Ryzen 9 3900X
- G.Skill Trident Z Neo (2 x16GB) 3600MHz CL16
- LIAN LI PC-O11 Air
- Coolermaster MWE Gold 750 V2
- 1 TB Aorus NVMe Gen4 SSD
- Corsair iCUE H150i RGB Pro XT, 360mm
- ASUS TUF Gaming GeForce RTX™ 3080 OC 10Gb
