Question Motherboard does not have wifi.
Yup, doesn't even have to be that fancy.
Make sure that you have your AV (and such) protections as well as the space between your ears set 'high'. Public WiFi can be a risk.
Might consider using a mobile hotspot solution.
Thank you for the reply, I am travelling to a family friends however their guest bedroom is across the house from the router so ethernet was a no-go. Security shouldn't be much of a concern. I appreciate the help
