Question Motherboard doesn’t have 24 pin slot
my motherboard doesn’t have a 24 pin slot for the new power supply i bought
That's because the motherboard's power input is proprietary. You're going to need a custom made harness/adapter for you to work with an off the shelf ATX power supply and that HP prebuilt.
What do I do?
It’s an hp intel i5
What is the model and SKU for your HP prebuilt?
Moved thread from Motherboards section to Prebuilt & Enterprise section.
Plenty of the off the shelf adapters for this very reason. Just need to know the exact motherboard to make a recommendation.
I have made my own adapter for a Dell in the past, but it does take some patience and having the right tools and mindset. Or you can spend like $15 on an adapter, often slow shipped from China. Or pay a small premium and get them from websites like moddiy.com
If that is an HP 8300:
https://www.moddiy.com/products/PSU...n-Adapter-Cable-for-HP-ProDesk-EliteDesk.html
This is why you have to do some research before attempting to turn an office PC into a gaming rig.
Honestly, it isn't even worth it, anymore. Look at the prices for a used Ryzen 5 3600, or 10th gen Core i5 gaming PC. I've seen them as low as $300, with 16 or 32gb and a graphics card, and it's going to cost you more than that to try to build out an office PC.
