Motherboard :- ASUS prime b660 plus D4
CPU:- intel core i7 12700F
RAM:- Gskill tridentz ddr4 3600MHz (4 sticks of 16 GB each)
Old CPU cooler:- intel stock
New CPU cooler:- deepcool castle 360 ARGB V2
So I basically got a bit of arctic MX-6 and changed my cpu cooler after which my motherboard's DRAM light stayed permanently yellow and the pc won't switch on, I have checked for bent pins and there were some on the side which I tried to straighten out as much as possible but no luck, I've also tried resetting, interchanging ram modules, and cleaning the back of the CPU itself with some isopropyl alcohol but no luck, what should I try?
[CPU socket and chip's image]
