Specs:
Motherboard: asus prime x570-pro
Cpu: AMD Ryzen 5 2600
Gpu: GIGABYTE RTX 2070 windforce (not used for diag)
Ram: 32G (4x8) ddr4 hyperX fury (1 8GB stick for diag)
OS: windows 10 on SSD ADATA sp550
Psu: seasonic gx-750w
So my buddy had a asus prime x570-pro motherboard that he bought to use in his new build. he said that when he got it he installed everything and it worked beautifully. he then was having issues one day with his wifi card that he had installed in one of the pcie slots where it would not connect to the internet so he replaced it with a usb style wifi adaptor and then after that it didnt boot anymore he thought that he fried the mobo somehow. i was wondering what the problem could have been so he gave it to me so i could try and figure it out. so i did a bare bones build with his motherboard matched with the components from my own pc. (all specs stated above are from my own PC except the mobo which is what im diagnosing) so i installed the CPU. 1 stick of ram (8GB) Connected all connectors in their respective places (24pin mobo connector and 8 pin CPU connector at the top) the mobo also has an additional 4 pin connector for the CPU which i presume is for extreme overclocking. i also connected my ssd with the OS along with the power cable for the ssd itself. i did not install a GPU since the back of the mobo has an HDMI connection so i assume that it has onboard graphics nor did i install a cooler of any kind since i am strictly testing to see if it will boot at all. i then tried to jump the pins for the front panel power switch with a bridge and.... nothing. no beeps, no light from the mobo RGB and no display. the motherboard also has its on power button on the board so i tried in and still no success. i then tried to replace the CMOS battery with one from my own motherboard and still nothing.
any ideas if it could be anything else or are we looking at a fried motherboard?
