So I threw together a new build today, after getting everything all hooked up for the most part I decided to test if the thing would power up. I plugged the PSU into the wall, flipped the PSU switch on, pushed the power button located on the case front panel and everything sprang to life except for the front panel fan which came with the case (big blue LED one on front). So I powered it off, re-plugged the fan's power cord and tried to turn the thing on again.
After doing all this I powered up the PSU again (which ignited a green light on the MOBO), then hit the power switch on the front panel of the case, but nothing happened. I'm pretty sure the MOBO is fine, as it's showing a constant green light (instead of flashing red), but I'm not sure what else could be wrong. I checked the power/restart cables on the MOBO and they were still intact, everything seems to be connected properly for the most part (maybe the psu power cords might not be connected tight enough?)
Anyways, I'm gonna head to bed -post suggestions for troubleshooting if you've got any, I'll give them a shot tomorrow.
Build:
G.SKILL Ripjaws Series 8GB
ASUS M5A97 R2.0 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
COOLER MASTER Elite 431 Plus
AMD Phenom II X4 965 Black Edition
CORSAIR TX Series CMPSU-750TX 750W ATX12V v2.3
SAPPHIRE Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP OC Version
1TB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive
LITE-ON DVD Burner
Build:
LITE-ON DVD Burner
