As the title says: Mobo turns on and all lights / fans working but no outputs working (USB, onboard graphics, etc)
I’ve just set up my first computer:
Intel i5 2400s LGA1155
Gigabyte GA-H77-D3H-MVP
Radeon RX 560
350 watt Corsair PSU
2 x 8gb DDR3 memory
1 Sata 7.5k 1tb HDD
240 gb SSD
I put together my first computer yesterday, transplanting the CPU, RAM and hard drives from my old computer.
At first I hadn’t plugged in the ATX 12v CPU power cord and so the computer would only turn on for a second and then die.
Now that I’ve sorted that out, the computer turns on and all fans in the case light up and spin as well as the GPU fan, and I can hear the hard drives spinning, but absolutely nothing else happens. My keyboard and mouse are not recognised, the DVI from both the GPU and onboard graphics both don’t work, I.e no outputs are functioning at all but everything else seems fine as far as I can tell.
The mobo speaker is functioning as I took out the ram and booted and got the beeps for that, but otherwise when I’m running everything there is no beeps at all so nothings wrong as far as I can tell.
Could I have fried my mobo or CPU? Or could my PSU not be powerful enough so that power to the fans and lights works but everything else doesn’t?
Interestingly I’ve noticed that although my phone doesn’t show that it is charging when I plug it in, it does actually go upon battery percentage so I would say there is power getting through to it.
Any help would be greatly appreciated!
Radeon RX 560
2 x 8gb DDR3 memory
1 Sata 7.5k 1tb HDD
240 gb SSD
