Mouse, Monitor or System Lag Help
91gtabird
Hello. I'm Brian and I am new to the forums. Ive been reading them for years but just posting here for the first time today. I've been searching for 2 days now and I have yet to actually find this problem/solution under my specific circumstances.
I've been playing on PS4 and Xbox One since their release and I have enjoyed it greatly. But I felt I've been missing some great games so I just built me a new gaming rig. I'm gonna post my specs first and then ill get to the problem after that's out of the way.
Here are my specs:
OS-Windows 7 Pro x64
CPU-Intel Core i5-4690K Processor 3.5 GHz LGA 1150 BX80646I54690K
Cooler-Cooler Master Hyper 212 EVO - CPU Cooler 120mm PWM
MoBo-MSI ATX DDR3 2400 LGA 1150 Motherboards Z97 PC MATE
Memory-Crucial Ballistix Sport 8GB Kit (4GBx2) DDR3 1600 (PC3-12800) 240-Pin UDIMM
PSU-EVGA 500 B1 80+ BRONZE
Case-Sentey Gs-6006 Z-tron Gaming Computer Case
SSD-Kingston 240gb SSD
Video Card-EVGA GeForce GTX 970 Super Clocked ACX 2.0 4GB GDDR5
Monitor(s)-HP w2007 1680 x 1050@60hz through DVI- -or-
Sharp Aquos 60" LED 1920 x 1080p@120hz through HDMI -or-
LG 47" LED 1920 x 1080p@120hz through HDMI
KeyboardOld Generic Compaq USB Keyboard
Mouse(s)New Wireless Microsoft Mobile Mouse 3500 Bluetrack and
Old generic wired optical mouse
Controller-Xbox One Controller (USB)
Here is the problem:
Whenever i'm playing games, i have a lot a lagging or stuttering when using a mouse and keyboard. It only happens when i move the mouse. I can run, sprint, walk, strafe, zoom and etc. perfectly smooth when using the keyboard inputs. As soon as I move the mouse though I get annoying stuttering. It happens to the same degree(game specific) on either of the 3 monitors that I have hooked up to.
When i use the Xbox One controller though, everything is as smooth as butter. I hooked up both my LG 47" displays and played State of Decay on Ultra Settings on one of them while using the other display to watch YouTube videos and it maintained a solid 60fps(capped) @1080p with MSI Afterburner monitoring. Even when using the Xbox controller and everything is running smooth, if i move the mouse, the game stutters. When using only the mouse and the game is stuttering/lagging, i'm still holding a solid 60fps so I am pretty confident that it isn't my GFX.
Another thing that happens also is that sometimes when i'm watching videos and I move the mouse, the cursor starts lagging. Not all the time though. Also there are some games that the mouse lags in the menus. My CPU and Video Card along with everything else is at stock voltages. Nothing has been modified or OC'ed. I've also not been able to adjust the dpi on the mouse. I have seen it suggested but i'm guessing my mice don't have the option. I don't mind buying a good "gaming" mouse if that would fix it. I just hate to spend another $50-60 for it and it not be the problem. I spent a lot putting this thing together and i'm getting frustrated over something so simple. So any help will be very appreciated. Here are the games that i currently play(with a controller) and a scale to which games are more problematic .
1=No Problems
9=Unplayable
-State Of Decay: YOSE (4)
-ARK: Survival Evolved(2)
-Subnautica(7)
-Unturned(3)
-ARMA 3(2)
*Notes*
-All games are run at max settings but have been scaled down to no avail
-All games work flawlessly at low to max settings with Xbox One Controller
-Subnautica slightly improves when windowed
Thanks, Brian
I'm fairly certain it's the 120 hz monitor and the game settings not matching the refresh rate. As well you should update ALL your drivers. GPU and Mouse/Keyboard. All of it.
I'm assuming this is the reply box that say's "Your answer"? I'm pretty sure I've updated every possible driver I can. I may be missing something so ill recheck. It does it on my 60hz 20" HP Monitor also. I've also set the LG tv's motion setting to 60hz just now and tried it but its the same. Does that mean anything? Would using the controller over the mouse have anything to do with the refresh rate? I'm only asking because I have no clue so i'm just playing 20 questions.
Thanks for the quick reply also.
