Mouse Problem - Not Quite On Topic
bill
1,834
Archived from groups: alt.sys.pc-clone.dell (More info?)
Got a problem with my mouse and Agent. When I had Agent running on my
Dell with Windows ME, when I had the cursor over a pane in agent, that
was the active pane. I switched to XP and lost that capability. Now
when I move the cursor from pane to pane I have to "click" the left
botton on the mouse once to switch the active pane.
The mouse is a Dell Logitech Wireless mouse. I contacted Agent and
they said it was a function of the mouse drivers. Not their problem,
I upgraded the driver when I installed XP.
Have you installed/are you using the Logitech Mouseware Program?
Dunno what version it is up to, but it allows you to configure
your Logitech mouse more finely than the default generic MS mouse
program. I've had 9.60 for quite a while now.
My Logitech optical, but wired, Dell branded mouse has always
operated in Agent the way you describe. Now, in the "Buttons"
tab of the Mouseware program, there is a box you can check/not
check "Use MS Office Compatible Scroll only." I don't have it
checked. Maybe if you check it, it will go back to working like
it did with WinME.
The same question was brought up once upon a time in the Agent
self-help newsgroup [alt.usenet.offline-reader.forte-agent] but
aging memory fails me on the eventual resolution. So the above
is the best shot I can offer.
[OK checked, they're up to 9.79 Build 25 now, and you can go here
http://www.logitech.com/index.cfm/downloads/categories/US/EN,CRID=1792,
find the mouse you have and click on it to get where you can
DL/update your Mouseware program.]
OJ III
[Email to Yahoo address may be burned before reading.
Lower and crunch the sig and you'll net me at comcast.]
Thanks, I'll give it a try.
On Mon, 31 Jan 2005 17:37:06 -0500, Ogden Johnson III
>it did with WinME.
Download the TweakUI powertoy for XP.
On the mouse settings page there is a setting called "activation follows
mouse (X-Mouse)" Check it and it will do what you want.
Steve Williams
Pacifism - The theory that if they'd fed
Jeffrey Dahmer enough human flesh,
he'd have become a vegan.
"Bill" <bnospamgross@nospam.airmail.net> wrote in message
news:sd4vv0l13cabk8l09h9hmajh38dth53lop@4ax.com...
my
that
Now
problem,
> >it did with WinME.
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
On Tue, 1 Feb 2005 20:38:32 -0500, "Steve W." <Dugdug56@what.com>
Didn't solve the problem. Acutally the problem is with Applications
such as Forte~ Agent. It has three panes in one window. When I
running Agent the computer (OS/Drivers/etc.) and am woking in one
pane, it's happy. It considers all three panes as the same thing,
when they are not.
