MOVE command does not work from .BAT or .CMD script
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
I have a .BAT file which moves backup files from the local hard drive to a
network share. It worked fine under Win98SE, but fails under WinXP. The
command which fails is:
MOVE /Y Backup\*.* \\ServerName\ShareName\FolderName
It returns a message "Bad command or file name".
If I open a command window, navigate to the same folder, and issue the exact
same command, it works fine. Any idea why the MOVE command would not run in a
batch file? Any way to make this work properly?
"Motek Kore Guy" <MotekKoreGuy@discussions.microsoft.com> wrote in message
news:B6132884-20CA-4E0B-AEDD-144F3E923354@microsoft.com...
exact
in a
There is something strange about your post. "Bad command
or file name" is a DOS error message - under WinXP the
wording is different. Furthermore, "move" is an internal
command under WinXP. If you have a Command Processor
then you have "move". I suspect the problem is caused by
some other command in your batch file, not by "move".
What other commands do you have in that batch file?
I agree, it's strange. The .BAT file is like this:
@ECHO ON
C:
CD "\Data Files\Accounting Data"
COPY *.* \\ServerName\ShareName\DataBackupDirectory
MOVE Backup\*.* \\ServerName\ShareName\DataBackupDirectory\Backup
The COPY command works fine. I get the "Bad command or file name"
immediately after the MOVE command (which is obvious as I have echo on), and
nothing gets moved. I can copy the command from the window and paste it into
another command box, and it works fine. I have tried renaming the .BAT file
to .CMD, and it does the same thing.
> exact
> in a
On Wed, 24 Aug 2005 20:33:47 -0700, "Motek Kore Guy"
>@ECHO ON
>C:
I'm guessing bad line terminator between the two lines, or a
non-printing character somewhere.
Stan Brown, Oak Road Systems, Tompkins County, New York, USA
http://OakRoadSystems.com/
"My theory was a perfectly good one. The facts were misleading."
-- /The Lady Vanishes/ (1938)
I withdraw my comment -- I think the point Pegasus bought up is the
key. "Bad command or file name" is not a CMD.EXE error message.
If you are somehow running through old DOS (COMMAND.COM), you may be
hitting a line-length limit.
Thank you, Stan, this was the hint I needed. I had all of the .BAT files,
along with shortcuts (.PIF) saved off in a folder, and restored the folder to
the XP machine. Apparently, .PIF files created in Windows 98 will work in
Windows XP, but invoke the COMMAND.COM processor rather than the CMD.EXE
processor. In Win98, it worked because MOVE was an external command, not an
internal one. I deleted the shortcut, recreated it, and now it works fine.
Thanks again!
--- Jeremy Segal
What's even stranger is that the error message "Bad command
or file name" does not exist under WinXP! There something
wrong either with your environment or with your reporting.
news:0CD1F9AE-366D-4E1F-A5E6-CBD547B06354@microsoft.com...
> @ECHO ON
> C:
and
into
file
message
to a
The
> > exact
run
> > in a
On Thu, 25 Aug 2005 10:19:02 -0700, "Motek Kore Guy"
I'm delighted you found the problem, but I think Pegasus deserves
the lion's share of the credit. He's the one who pointed out the
error message couldn't possibly be right -- I didn't pick up on the
COMMAND.COM issue at all till I saw his note.
Anyway, thanks for letting us all know. It's so satisfying when a
nasty mystery turns out to have a simple explanation!
"What in heaven's name brought you to Casablanca?"
"My health. I came to Casablanca for the waters."
"The waters? What waters? We're in the desert."
"Stan Brown" wrote in message
news:ijbug15hacba8mhbervvj1fa32kcho4jbr@4ax.com...
folder to
an
fine.
Maybe, but it was your post that finally nailed the culprit.
