[SOLVED] MPG X570 GAMING EDGE WIFI
Apr 16, 2020
6
I just built this computer the motherboard is the title .MPG X570 GAMING EDGE WIFI. it has a RYZEN 5 3600, Ram is VIPER 2X8GB STICKS DDR4 UDIMM- PC4-32000 4000MHZ, POWER SUPPLY is 650 rated with the gold 80, im pretty sure its corsair. video card is a MSI 580 ARMORED GDDR5 8GB. Have a 970 evo plus 500gb, m.2. When i run cina bench after almost 30 seconds the computer shut off, for some reason I cant figure it out. Can someone give me a couple ideas of what it could be.......plz..thank you
ram is in the 2 and 4th slot it was running at 4000mhz , I just turned it down to 3600 so im gonna see if it will run.
You should run the RAM at 3600MHz. It's the sweet spot for a Ryzen 3000 and I think that anything over 3600MHz kills the 1:1 infinity fabric ratio. I could be wrong on that last part.
Run them at 3600MHz and see if you still have instabilities.
Normally a system shutting down or restarting by itself is an overheating, PSU or GPU issue.
yeah it ran single core, for ten minutes good score. but multiple cores it shut down and that was at 3600. So i just put the wraith cpu fan cooler that came with the cpu, I have a brand new Liquid cooler by cooler master I wounder if it is getting toohot.
I asked for the temperature of the CPU / GPU at idle and load but you didn't give me an answer :)
Im so sorry I ended up taking my cpu cooler that came with the cpu u off and putting my water cooler i had on . and i added three more fans. Thank You Very much it was a heating issue. you where very helpful.
