MS32Info Problems
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Every time I try to retrieve advanced system information about my computer
using the "Tools & Help" menu I get a pop-up window that says "Error 2". Is
there any way to fix this? I'm trying to get the MAC address for an
installed wireless card without having to open the box. I've also tried
fixing using one of the recommended sites but still get the same problem.
Every I try to launch MS32Info I get a message stating "Error 2". The Tools
and Help is the help that comes with Win XP. Within the help you can
navigate to a page that allows you to launch MS32info. Regardless, the
utility does not work.
Lamar Family
DKLamar@comcast.net
"DLamar" <DLamar@discussions.microsoft.com> wrote in message
news:B176BA63-338E-4EFD-8F11-BC8ED6BEC234@microsoft.com...
> Is
Hi,
I don't see any "Tools and Help" menu in MSINFO32. To find the MAC Address,
open MSINFO32. Double-click Components, double-click Network. Select
Adapter. In the right-pane you'll find the required info.
Ramesh, Microsoft MVP
Windows XP Shell/User
http://windowsxp.mvps.org
> Is
System Info tool requires WMI Service to be running - is it? You may need
to repair WMI; google for it.
The simplest way to get the mac address(s) is to use the command line:
open a "Command Prompt" (start | accessories | command prompt)
type: getmac
if you have more than one adapter you will need to figure out which one is
which. disable them one at a time and repeat to figure this out.
type: exit
