MSI 865PE problem
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.msi-microstar (More info?)
I had a MSI 845 board in one computer. That one shorted out. Long
story.
Got a MSI 865PE NEO-2 board in a new case with a serial drive.
I put my old IDE HD in has as IDE master, did a Windows repair
install and it seem to work find, got back to work. A couple programs
had to be reinstalled.
But I cannot boot to that drive with the ATA config, in bios, set to
either PATA or SATA with Native and any variety of other settings.
If I set it as PATA and SATA (with Legacy) it will boot but the bios
won't recognize the secondary HD controller.
IN boot I can the first Windows splash screen for a second or so and
then ir recycles back through the boot process.
But if I boot to the Serial drive with SATA set, the controller can be
seen.
I cleared the CMOS but no change.
Wrote the MSI, nothing.
What Im down to is that many the repair install left over something
that it hanging up booting into that drive.
On Fri, 24 Sep 2004 05:04:43 GMT, John Johnson <change@pacbell.net>
>story.
>seen.
Maybe this will help.
http://forum.msi.com.tw/thread.php?threadid=21469&sid=c522fbc7991540c95ca44a0d5389a338
On Fri, 24 Sep 2004 10:04:34 -0700, Griffin McKorn <JPP@ZoSo.org>
>>story.
>>seen.
Thanks but I have been checking out that forum, seems a couple of
others have similar problems.
As I said, I have tried every combination in that bios setup and
nothing lets me both boot up to the primary IDE drive and see the
secondary IDE drive.
Which is what I want to solve.
Have you tried this
ATA OnChip Operate Mode: Native
ATA Config: SATA
PATA Keep Enabled: Yes
PATA Channel Selection: Both
>>>story.
>>>seen.
On Sun, 26 Sep 2004 03:27:39 GMT, Mike <mejacobie@netscape.net> wrote:
>Have you tried this
>ATA Config: SATA
Yes, that way on Boot it runs into something it can't load so doesn't
even tried to get to Windows.
Like its looking for a serial drive and can't find one, (its
unplugged.)
I do have a serial drive which I eventually will switch over to but Im
in the middle of a project and its going to take some time to
reintsall everything.
>>>>story.
>>>>seen.
