Those are WAY more than you really need. Nothing wrong with a larger unit, but the GTX 960 only requires 450w and yours apparently also an 8 pin. Most 960's only need a six pin, but some have different configurations. Still, 750w would be enough to run two of those in SLI. I'd go with the unit I linked to earlier, or this, if you want a larger capacity unit in case you upgrade to a bigger or second card down the road. Those other units are just overpriced for what you're getting.
PCPartPicker part list /
Price breakdown by merchant
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($73.99 @ SuperBiiz)
Total: $73.99
Generated by PCPartPicker 2015-07-25 22:36 EDT-0400
AND, NCIX US, which I fully trust, has an additional 30 dollar mail in rebate on that unit currently, so it only ends up costing you like 45 bucks. Very reliable unit, semi-modular, did Silver in JonnyGuru testing for efficiency even though they only list is as Bronze. 80plus efficiency is not a reliable method of determining quality anyhow so I wouldn't place too much weight on bronze, silver, gold, platinum ratings.
