[SOLVED] MSI Motherboard RGB Header with Cpu Fan RGB
Mar 2, 2019
I have the msi z370 gaming pro Carbon ac and I’m not sure if I should connect my coolermaster 171c cpu cooler to JRGB1 or Jrainbow any help would be much appreciated and also if you guys can also help I can either connect my case leds to the mother board to but not sure which rgb header to put it in the case is Deepcool matrix Add RGB Very Big thanks for any help.
Just asking because I don’t want to mess any components up
Use one of the the JRGB1/2 ports. The nr 2 is next to the 8pin cpu power connector which is quite close to the cooler.Make sure the arrow sits on the right side of the pins. If not having this cooler already might want to look at the Cooler Master Hyper 212 Black edition with rgb,this will be a better cooler.
https://pcpartpicker.com/product/hH...ck-edition-573-cfm-cpu-cooler-rr-212s-20pc-r1
if you have the budget for it.
