Archived from groups: alt.games.neverwinter-nights (
More info?)
"Khazad Dhum" <BMacklem@milwaukeepc.com> wrote in message news:<VBrlc.9096$0K.447@twister.rdc-kc.rr.com>...
> It would be best and faster to level up the split way you mentioned....one
> thief..then one fighter...next thief and so on.
> The reason for this is depending on your race, you most likely would end up
> with an experiance penalty if your class levels get more than one or two
> levels apart from each other. an xp penalty means that a percentage would be
> deducted from what you would recieve from defeating a monster...i.e. if you
> would get say 100 xp for a kill, you would actually only recieve 80 or 90 if
> you're under a penalty.
> as long as your classes are only 1 level apart you shouldn't get any
> penalty.
Unless you are a halfling, in which case the Rogue levels don't count
towards that exp penalty check. Or a Human or Half Elf, in which case
you don't count your highest level class.
Funny thing is, I've had that wrong all along, and thought that a
4/4/1 split was a good one with a human, when really a 5/2/2 type
layout would be the one with no penalty.
Simple two class combinations though, if you are a human or half elf
you can't go wrong.
Hmm, here's another question I haven't looked into. Are Prestige
classes counted for this exp penalty thing? Because I can't think of
many prestige classes you can buy without 6 levels or so in one or two
other classes. That means you start out with the prestige class 5
levels too low. For a human or half elf, no problem, but for any
other race, does that automatically put you behind the eight ball, so
to speak, until you "catch up"?
And since you had to buy 6 or so levels in that class before getting
any prestige levels, does that mean the "other races" have to either
keep raising that first class to keep up or suffer penalties when
getting past 7th level in their "real" class (I know they can only go
to 10 pre 20th, but then its 10/10 and they can go 20 more in the
prestige class, are levels 22 thru 40 all going to be at a penalty if
they do it that way?
Wow, I never should have tried to answer this question, now I've
realized how much I don't know!
Lance
