Should I go with Multi-GPU Solution to increase framerate?
I am also worried about Software Compatibility as well as MicroStutter issue.
I am not so sure how does AMD Frame Pacing work, but my question is, will Frame Pacing eliminate Micro-Stutter when running at Single Display Monitor?
If I go with R9 280X Crossfire, will it take advantage of super high refresh rate 144Hz or greater such as ASUS VG248QE and BenQ XL2420TE?
