Multimedia Audio Controller Drivers
Bucholly
4
Hi Folks
I reinstalled XP home onto a Parcard Bell iMedia 1404 tower
but it failed to install the Multimedia Audio Controller Drivers.
Packard Bell no longer have the drivers and am unable to locate the collect driver i=on the Gigabyte Motherboard
website, can anyone help PLEASE?
Cheers
Oh and Seasons Greetings to you all!
Bucholly
Model/Type Found onm Label ob rear is: UTOW-C02! but that does not appear on there site, I rang support they said check out GigaByte site, I could not find an entry for that driver, unless its under a different heading! The Motherboard model No. is: GA-8SiMLNF. Cheers. B
Look here http://forum.giga-byte.co.uk/index.php?topic=3625.0, looks like it's an OEM board so Gigabyte won't have support for it, or at least support that's easy to find.
If you can't dig one up, buy a $10 sound card to use.
Thanks for that matey! Yes I gug a soundblaster card out of the attic and it's now doing the
job!
Thanks for trying.
Have a great Xmas and New Year.
B
