Question Multiple fans in a single Fan header!
Feb 25, 2019
I have a Gigabyte AB350 Mobo with two RGB headers, Is it possible to connect 5 Masterfan mf120l(0.37A each) fans to it and get them synced to RGB Fusion, will also be purchasing a Masterair MA610P, which includes 2 more fans! So can all these fans be synced together by any means.
Thanks!
RGB strips/lights go to the RGB headers, RGB fans go to the fan headers. You can put 2x fans per header safely or use a powered splitter for upto 4x fans.
Corsair also sells an RGB splitter, will handle upto 6 RGB fan lights from a single RGB header.
This is handy since you can control separately the different areas, exhaust and intakes, yet control all the lighting from 1 source. The RGB splitter requires a Sata power source and a link to an RGB header.
So will this work?
[₹368.05]Akasa AK-CB002 PWM Splitter Smart Fan Cable Supports 3 PWM Fans From A Single Motherboard Header Computer Components from Computer & Networking on banggood.com
https://banggood.app.link/3HYIjivEAU
It has 2 3-pin headers but the coolermaster fans have 4pin support! Will it work?
