Hello everyone. Yesterday I received my new graphics card, a Sapphire Pulse Radeon RX 550. I installed the card and the associated drivers, which I found on the AMD website using their auto-detect system first and then manually locating the correct driver second. Now I am having multiple issues. First off, I tried benchmarking my computer using UserBenchmark, but the program returned an error when testing the GPU: "WARN: skipping Radeon RX 550 Series - unable to locate attached display". I encountered a similar problem when trying to refresh the Windows Experience Index: "Could not measure video playback performance". Second, when I go to Control Panel>Appearance and Personalization>Display>Screen Resolution, the resolution drop down menu is greyed out, and nothing happens when I click on Advanced Settings.
I have done several things to troubleshoot, many of which I found on this site. I tried uninstalling/reinstalling the device drivers. I used Display Driver Uninstaller (from Guru3D) to remove all display drivers, old and new, and then reinstalled the new ones. I have made sure to install all system updates and driver updates. Some specs:
OS: Windows 7 Professional 64 bit
Monitor: HP W2071D (connected via DVI)
MOBO: ECS IC780M-A2
Processor: AMD Athlon II x2 265
Memory: Corsair XMS3 8GB (4GBx2) 1333Mhz
Please help, I really don't know what else to do or try. EDIT: I should add that the display itself works fine, I was able to run Kombustor to test the card as well. Afterburner registered GPU activity. ALSO: In Device Manager, the Display Adapters drop-down lists Radeon RX 550 Series.
MOBO: ECS IC780M-A2
