My comp restarts on its own, plz help
TheFuzzer
15
I don't know what the problem is but off and on my computer screen will turn black and I'll hear a slight high pitched sound and my comp restarts to the bios and reloads XP. What's causing this?
My System:
MSI KT266A PRO2 mobo
256MB DDR
AMD T-bird 1.2 GHZ
Asus geforce 2 gts 32mb ddr
turtle beach santa cruz sound card
With the little information you have given us, I would venture to say that your problem is an inadequate or failing power supply.
I can't think of a good signature so I'll use this one.
what other info would u like? I got a 300W PS. I have an 8x DVD burner, a 16X Plextor burner, a 40 Gig Maxtor 7200rpm HD, a generic ethernet card, a volcano 7 over the cpu, a back case fan and a blower in a pci slot.
Usually, even with all that stuff, a decent 300 watt power supply would suffice. I say decent because a lot of generic cases have crapola power supplies made by L&C technologies and other fly-by-night companies. Frankly, these power supplies are dangerous. I've had several of them literally blow up. Inside, capacitors exploded. On one occasion almost causing a fire.
You could also try updating the latest BIOS.
<A HREF="http://www.msi.com.tw/support/bios/bios.php?model=MS-6380+V2.0" target="_new">http://www.msi.com.tw/support/bios/bios.php?model=MS-6380+V2.0</A>
One other thing could be over aggressive RAM timings. You could try backing them down a bit. But more than likely it's your power supply. I have my K7T266 Pro 2 with the most aggressive settings and it works like a champ.
Good luck.
Get a good name brand like Antec or Enermax that has at least 400 watts. Nowadays their fairly inexpensive.
