My components perfomring low
It says it is performing at the 49th percnetile. That is middle-of-the-road, 1/2 faster and 1/2 slower. You have the RAM running at default clock (2133). Try the DOCP (AMD XMP equivalent) to bump the RAM speed.
The RAM has been tested by the manufacture (based on your screen shot) to 3200. Your motherboard may only run it at 2933. But it is worth trying it. It is a BIOS option that is pretty easy.
Your components seem normal to me. You are just comparing your "stock" settings to systems that have overclocks. Kind of like comparing a Kia to a Corvette. Both cars, but performance is no where near the same.
I would try the DOCP option first. That is the most straightforward. Otherwise, you may have to set timings and voltage manually. Not great for novices.
Since you didn't put the OS on the SSD, I would wait until you can purchase a 240GB or a 500GB SSD to do the OS thing. 120GB is just too small any more. You have to watch your free space all the time.
