my cpu using 20 watt
Likely your GPU is not fast enough to fully utilize the CPU, so it has some idle time.
This would depend on the game, resolution, and settings. If you don't see a performance increase by reducing graphics settings then something else is the problem.
MSI afterburner can do a quick job of telling you if the GPU is reaching maximum load (you can also track CPU usage at the same time)
