Question My ethernet is slower than my wifi out of nowhere
Peanut132
41
Out of nowhere i noticed my internet was a bit slow so i checked the speed and it was slow so i called the isp n they said the speed was fine so i checked the speed using wifi and it was fine too but when i check it the speed on my pc using ethernet its stuck at like 9/10 mgbs i changed cable, reseted router, diasabled wifi, disabled wake up on lan nothing worked. I had the same issue with my other laptop but when i unplug and plug the cable the speed goes from 9 to 90mbs i tried unplugging and plugging on this pc but didnt work.
C:\Users\omara>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : DESKTOP-L3U0SE0
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wi-Fi:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Qualcomm Atheros AR9287 Wireless Network Adapter
Physical Address. . . . . . . . . : 18-A6-F7-F1-6B-24
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Local Area Connection* 1:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 1A-A6-F7-F1-6B-24
Wireless LAN adapter Local Area Connection* 2:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : 2A-A6-F7-F1-6B-24
Ethernet adapter Ethernet 2:
Description . . . . . . . . . . . : AnchorFree TAP-Windows Adapter V9
Physical Address. . . . . . . . . : 00-FF-F7-96-C1-48
Ethernet adapter Ethernet 4:
Description . . . . . . . . . . . : Windscribe VPN
Physical Address. . . . . . . . . : 00-FF-09-3C-55-6E
Ethernet adapter Ethernet 3:
Description . . . . . . . . . . . : AnchorFree TAP-Windows Adapter V9 #2
Physical Address. . . . . . . . . : 00-FF-EC-BA-C6-AB
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller
Physical Address. . . . . . . . . : 2C-4D-54-CF-5C-05
Link-local IPv6 Address . . . . . : fe80::65fc:5831:a4fe:a116%21(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.7(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 25 November 2020 17:21:07
Lease Expires . . . . . . . . . . : 26 November 2020 17:21:06
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 304893268
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-23-77-25-9C-2C-4D-54-CF-5C-05
DNS Servers . . . . . . . . . . . : fe80::1%21
192.168.1.1
fe80::1%21
NetBIOS over Tcpip. . . . . . . . : Enabled
This is the ipconfig/all
I tried disabling ipv6 too didnt work
and when i check the status the speed is 10
jojesa
Illustrious
Try resetting all network connections on your PC.
Open Windows Settings (Windows key + I key), click 'Network & Internet'.
Select 'Status' on the left pane and on the right click the 'Network reset' link.
That will reset all network settings to default.
Peanut132
41
I tried it now and i restarted the pc at first the ethernet was going identfying then disappear so i went to control settings i disabled it and i enabled it again now it is connected but the speed is still stuck at 9mbs
jojesa
Illustrious
Set network speed manually.
Click on 'Change adapter options'
Right click you Ethernet connection
Select 'Properties'
Select 'Configure' button
Select 'Advanced' tab
Find 'Speed & Duplex', and if it's on 'Auto Negotiation', change it to match the speed of your PC network and your router port.
Press 'OK'
If your PC has a Gigabit network and your router has Gigabit ports then select '1 Gbps Full Duplex'
If your PC has a Megabit network and your router has Megabit ports then select '100 Mbps Full Duplex'
If your PC has a Megabit network and your router has Gigabit ports then select '100 Mbps Full Duplex' and viceversa.
Peanut132
41
Select 'Properties'
Press 'OK'
I tried it and i sat it at 1gbps full duplex and when i tested the speed was 1mbs so it decreased so i just returned it to the normal auto negation
Peanut132
41
Tbh i dont know the router model but its a one provided by the isp and its new its their latest so should be able to support the speed and it was working well anyways till few days ago
I already tried other ports and cables and reseted the router still the same
Peanut132
41
Download a diferente driver version for your Ethernet controller.
Uninstall the Ethernet network controller from Device Manager and delete the drivers.
Install the downloaded drivers.
Oke i tried diffrent verisions of drivers still the same
btw in the status in adapter settings it says 10mbs so maybe thats capping it but i checked the speed and duplex its auto negoation and i tried 1gbs full and it became slower
plz im struggling with this issue its so annoying
Peanut132
41
Oke so an update i have a usb 3.0 to ethernet adapter i use it for my laptop so i said i might give it a shot on this pc and now i have the full speed and in status it says 100mbs so this is a temporary fix cuz now my laptop have no internet
Peanut132
41
Okay when i restarted my pc the internet was back at 10mbs i kept pluging n unpluging the adapter several times until it gave me the right speed so what could be causing this and how to fix it
jojesa
Illustrious
If your laptop is hitting 100Mbs and the USB to Ethernet adapter gets 100Mbs then the issue is with your PC Ethernet port, chip or settings.
Visually look at the Ethernet port in case it is damaged.
I was looking at your IP Config results and there are 7 network adapters listed.
Delete them all, reboot, and let Windows configure it
On your DNS entry it shows.
192.168.1.1
fe80::1%21
It should be DNS Servers . . . . . . . . . . . :192.168.1.1
If you have not manually change it the the TCP/IP Stack could be corrupted.
To fully reset TCP/IP Stack
Open Command Prompt as Admin
Type each command below, hitting the Enter key after each one. After each one resets you will see 'Restart the computer to complete this action.' Move onto the next command and after you have completed all the reboot
netsh winsock reset
netsh int ip reset
netsh interface ipv4 reset
netsh interface ipv6 reset
netsh interface tcp reset
netsh int reset all
ipconfig /flushdns
nbtstat -R
nbtstat -RR
netsh interface tcp set global autotuninglevel=disabled
netsh advfirewall reset
Peanut132
41
192.168.1.1
fe80::1%21
netsh winsock reset
netsh int ip reset
netsh int reset all
ipconfig /flushdns
nbtstat -R
nbtstat -RR
Oke ill do it asap
No also the usb to ethernet is stuck at 10mbs but when i keep plugging and unplugging it then it works fine which happens both on the pc and laptop so maybe its it's something with the router
